Announcements
Beams Concrete Quantity
jazzsharma200
jazzsharma200
I have modeled 2 Floors in Revit each floor has beams, in Schedule, no beam is assigned to the floors.
How can we sort the Beam Concrete Quantity Floor wise?
this problem is the structural walls also.
ovidiu_paunescu
In Revit the beams are not assigned to the floor, they are placed on a workplane and have a reference level.
They are cut by the floor
You can use a material schedule to get the volume of material for all those elements. If you want to get that volume by level and added together, you will probably need to add a common value to a parameter (like Comments) and filter by that in the schedule.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
WEC17
If you want to to do it by floor, you can do this:
Lets say you call your beams "2 B1" (2 ref. 2nd Fl. B1 for the designation" This is you type. when you tag it should read "2 B1". Also click on Edit type an on the type mark put 2 B1. This should take care of the plan.
Schedule:
When you get to the schedule you need to do this:  Pull in all your Field including type mark.
Filter by type mark/contains "2"  All the beam from you second floor will show up.  do the same this for the 3RD fl. and so on.  this way you can schedule all you beams by floor.
Let me know if this works for you.
