10:28 AM
Hi all,
I have a beam connected to the beam with the specified cutback on both sided.
Blue beam is connected to the green one. I have adjusted the alignment reference (Change End Reference button) for the blue beam (as depicted in the state '1'). When I reload the green beam family to the project environment the alignment reference with the green beam is losing its desired reference (state '2') and goes back to the default bounding box of green beam.
Any suggestion what could be the issue here?
Link copied
