Beam System shenanigans
itsme.mozzarella
itsme.mozzarella
I'm having an issue with the functionality of the Beam System. I've made a boundry in which I want 14 (Fixed Number) beams placed evenly, starting and ending with a beam, not with empty air. Why is it that Revit 2019, when told to place those beams evenly in a specified boundry, places them as seen in the screenshot?
Alan.johnson1970
The beam system tool is meant for placing the secondary beams (joists/pulins) between beams.
Not for the primary beams that go column to column. So it doesn't place the first and last beam.
AJ.
dferreira-blackwell
AS You can see from the beam system icon itself, it will place blue highlighted beams not the end ones.
