beam-slab can not join
A_MAQ
Advisor Advisor
Message 1 of 9
A_MAQ
hello all,
below are beam and slab can not make join
what is the solution ?
greetings
Autodesk Expert Elite
Replies (8)
Message 2 of 9
constantin.stroescu
both beam and slab must be of the same material . For instance Concrete cast in Place - must be the same name for the material. Then , use Join, select the slab and the beam ( only the conrete layer of the floor will join the concrete beam)
Constantin Stroescu
Message 3 of 9
A_MAQ
i did ,but is useless
Message 4 of 9
avis_ambalathil
The reason is with the family. If we put the material behaviour of the beam as concrete and put the visibility of the 3d geometry(sweep) to be visible in coarse, medium and fine then this family will auto join with slab or other concrete beams in project.
Next, if we put the material behaviour other than concrete(steel), and put the visibility of the 3d geometry(sweep) to be visible in coarse, medium and fine then this family can be used with join tool in project. We can select the beam using join tool.
In most of the structural framing family, the solid geometry will be set as invisible in coarse mode.
Message 5 of 9
RPTHOMAS108
Is edge of beam perfectly aligned with edge of floor? From my tests it tends to remain un-joined even after such initial misalignment is corrected, until joined manually.
Message 6 of 9
cristinapaz.arq
Community Visitor
Community Visitor
I had the same problem, my slab was 20cm deep and my beam had the same size. Revit showed me the warning that if I joined them the geometry would be lost inside of the other. So what I did: I increased the beam a liiiiitle bit, in a way that quantifications wouldnt be affected. And that was it. They joined perfectly.
Message 7 of 9
francesca.duffizi
In case you have both beams and slab of the same width, you have to change the heigth of the beams in order to make them bigger then the slab, do the join (as @cristinapaz.arq suggested), but after that you can reset the beams heigth to the original value (not affecting drawings, quantifications etc).
Hope it's a useful trick 🙂
Message 8 of 9
carlose.jaimes
Observer
Observer
One of the best answers I've ever read. Thank you so much, It worked for me
Message 9 of 9
Ilic.Andrej
7 years later...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
