beam not connecting to corbel column
adper27
adper27
wondering why beam isn't connected with corbel column. although blue dots is center to center with the column
Thank you in advance for the prompt reply.
ovidiu_paunescu
Hi @adper27
That is strange
I tried modelling that from scratch and the elements join correctly.
Could you add a sample model showing the issue?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
adper27
see below-attached sample file and look grid 2/a  corbel column location.
thanks.
ovidiu_paunescu
The column Material for Model Behavior is set as Precast Concrete.
This means that the element is not joining with other Concrete elements, like the beam
You can the material to Concrete and the beam will join correctly
Alternatively, you can make the beam Precast Concrete and adjust the cutback
