Beam missing on one level but not in the other
Nicole.cater001
Nicole.cater001
I have the setting to fine and that doesn't seem to be working. I also have the VG on but nothing. And it's just this floor that's doing it. I'm still learning the program but would love to learn so it doesn't do it again.
eizinmyat
How about creating structural plan! I attached the links so that you can check. Or trying  with checking the Show Center Line checkbox in the Floor Plan and Section panel of the Beam Settings Dialog. I hope it could helps you.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Beams-are-not-visi...
https://community.graphisoft.com/t5/Documentation/Beam-not-visible-on-Floor-Plan-although-in-Range-v...
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
metehanhanedan
Hey,
It may be because of the view range settings. While in the plan view can you check view range settings from properties window.
I am dropping a link for you to understand view range better.
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
ennujozlagam
can you see it in the section view? change your detail level to FINE.
jay_colcombe
Obviously we need to find out what the issue is the location lines are there and this would indicate some measure of  visibility, would I be correct to assume these are Beams Systems and could it be that you copied the Beam System but not the Beams?  In 3D are all the beams shown in a 3D View?
Also if they are Beam Systems do they have beam sections assigned in the Properties Palette?
To check if this is a Visibility Issue and quickly resolve this to get to a working state you could open the Working View
View Tab > Graphics Panel > View Template > Create Template from Current View > Apply to Non-working View
Jay Colcombe
Autodesk Certified Instructor
Nicole.cater001
Yes and I have it already fine
