Beam/Column Joins
Beam/Column Joins
Beam/Column Joins
When I tried to adjust how beams and columns frame into one another with the beams/column joins icon, some nodes of the model are available and others aren't. You can see in the picture below nodes within the red circle aren't available. Could anyone help me? I really appreciate your help
Best regards,
Cesar
erik_snell
The columns need to be slanted columns to play in the joins. Slanted columns can be vertical however vertical columns can only be vertical. When switching pay attention to the rotation as the orientation changes for pure vertical and slanted vertical columns.
Autodesk Logo
Erik Snell, P.E.
Experience Design Architect
Autodesk Revit
I am an Autodesk employee and the opinions or commentary I provide are my own and not necessarily that of Autodesk, Inc.
