I am working on a project in Revit where I have a structural concrete stub column with a steel column on top, which includes a base plate. When I attempt to lower the level of both columns:
Issue with Movement: The steel column moves with the level change, but the base plate does not follow, remaining at the original height.
Error on Recreation: If I delete the base plate and try to place a new one at the correct level, I receive an error stating "Invalid type or number of input elements".
