Hello
I'm trying to attach a column to a sloped slab. I tried first to do it to a horizontal slab, that was OK. After that I made a slope arrow and the column doesn't change. I know about the attachment style ( cut target) and intersection as seen at the first picture. I tried to remove constraints to ref. plane in the column family ( the second picture). Any suggestions, please? Need help ๐
Solved by sabina.vladimirova. Go to Solution.
@ToanDN suggestion is correct. can you post your file so we can check. thanks
I found some decision for graphics ( column 1-B) , but it is not good. The column is not attached. Here it is the file attached.
