arrow-ticket dimension properties
Jason.P
Message 1 of 12
Jason.P
Does any one know how I can get my dimension arrow to flip when I reach a small dimension using the arrow-tick style. We like to show our dimensions as arrow to grid and tick to all other elements. I have attached a photo. Any help would be great
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Replies (11)
Message 2 of 12
ennujozlagam
I guess arrow dimension sizes in Revit are pre -defined and you cannot be able to control the sizes unless you created a small size? Thanks
Message 3 of 12
Jason.P
we have an arrow-arrow dim style and when the dimension is small the arrows flip out, but the second I try it with our arrow-tick the arrow will not flip out.  Is there a way to get that arrow on the arrow-tick dimension to flip out when over lapping the tick.
Jason Peters
BIM Manager
Message 4 of 12
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Jason.P
Can you please upload the model/family in question? Thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Message 5 of 12
Jason.P
Hi @andrea.kikuchi
I have attached a model and set up a couple dimension examples, so hopefully it is pretty obvious what I am talking about.
Jason Peters
BIM Manager
Message 6 of 12
andrea.kikuchi
Autodesk Support
Autodesk Support
Thank you for uploading the model. I'm not sure exactly what you are looking to accomplish here, can you provide an annotated screenshot of what you need? Thanks!
Andrea K
Message 7 of 12
Jason.P
Here is a screen cap with some annotation explaining my request.
Jason Peters
BIM Manager
Message 8 of 12
andrea.kikuchi
Autodesk Support
Autodesk Support
Can you change the scale? It looks to appear with both arrow and tick mark at 1:50 scale.
Andrea K
Message 9 of 12
Jason.P
Do you mean, change the scale of the drawing? IF so, yes, but I have it at 1:100 to show how the arrow on the arrow-tick dimension style will not rotate out of the dimension line when the dimension gets to small.
Jason Peters
BIM Manager
Message 10 of 12
andrea.kikuchi
Autodesk Support
Autodesk Support
I understand. I took a look at the model you shared and see that the arrow you are referring to is an ordinate dimension which doesn't have the functionality to flip the dimension due to the nature of what an ordinate dimension is representing (distance from an origin). This is what is happening in the Continuous Dimension shown at the top dimension string. The direction of the arrow tick mark matters for Ordinate dimensions because it's showing the dimension from the origin.
As a workaround you could set the Dimension Line Extension for this dimension to show the desired line, but you may need to create a separate additional dimension type to avoid showing that extension for cases in which it's undesirable.
Andrea K
Message 11 of 12
Jason.P
Thanks. Any suggestions on how to set that up. Creating dimension types are not my thing.
Jason Peters
BIM Manager
Message 12 of 12
Jason.P
thanks everyone, we came up with a pretty slick way to fix our problem and a nice little dynamo routine.
Jason Peters
BIM Manager
