arc changes it center while flexing (family creation)
abid.islamain
Message 1 of 9
abid.islamain
hello everybody,
I want to create an arc in one quadrant of the front view using extrusion with R1 and R2 as shown in image. it works when I change the radius but when I array it in one direction as shown in 3d image then changing the radius of arc extrusion displaces the center. the radius does changes but with different center.
I am attaching the family as well. I am using Revit1.PNG2.PNG3.PNG 2020
Replies (8)
Message 2 of 9
RDAOU
@abid.islamain
It is not clear what you are trying to model...Do you want the array to behave like an offset?
Message 3 of 9
abid.islamain
I want to create a solid arc with inner and outer radius and some depth
Then array it on certain length with spacing as parameter
Message 4 of 9
RDAOU
Image above is a capture of your original Post...
  1. In Family Editor - Arrays, the Radius of each component instance cannot change if they are grouped and associated. It will always be the same Radius
  2. When you array a circular element, the element gets copied/repeated every X distance and/or X number of time Subsequently displacing the center
=> the behavior you described is a normal behavior of an Array
See the image below of an Offset vs Array ...the former you cannot achieve using Array in family editor
Message 5 of 9
abid.islamain
@RDAOUyou arrayed the circular element on right side what i want is to array the same circular element on back side and keep the center same every time I change the radius of element
Message 6 of 9
RDAOU
@abid.islamain
Depends on how you array (ie: Append new instances to end or in the middle). Append new instances to end - Constrain its center of the first and second instances of the array to the vertical and horizontal ref planes
Message 7 of 9
abid.islamain
Message 8 of 9
RDAOU
@abid.islamain
Do not array the extrusion directly in its family...
  1. nest it into a host generic model or generic line based
  2. Unche l work plane based ... the child family doesn't need that
  3. Once nested, lock the vertical and horizontal planes to those in the host
  4. Array the lock 2nd instance
Message 9 of 9
abid.islamain
thank you for your time it worked
