Anchor bolt
Anchor bolt
Message 1 of 16
Anchor bolt
Dear colleagues,
I want insert M52 anchor bolt but I can't find "M52" diameter in standard.
How can I create or load M52 anchor bolt?
Thanks!
Replies (15)
Message 2 of 16
eric.zhang305
This link might help you with changing anchor bolt sizes.
Please select the Accept as Solution button if my post solves your issue or answers your question.
Message 3 of 16
Have you tried Googling it? I find an awful lot of Revit families with a keyword search.
Message 4 of 16
eric.zhang305
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Message 5 of 16
catalin_lang
Are you referring to the Anchor Bolts from the Steel ribbon?
If so, you cannot add other entries to the list.
In this release only the provided anchors with Revit are available.
catalin.lang
Message 6 of 16
Yes from Steel ribbon. Are there any other method?
I am using 2019 version. And I am new Revit user.
Message 7 of 16
catalin_lang
No, there is no way to add other entries in this version. It is a know limitaiton that will be addressed in the future version.
Please add this need to Idea station.
catalin.lang
Message 8 of 16
Thank you for your response. Is it possible to load additional anchor bolt family?
Message 9 of 16
eric.zhang305
Here is a link to additional families.
Message 10 of 16
Thank you! But these are detail families, I need anchor bolt family.
Message 11 of 16
Revit has over a dozen different Anchor Bolt Model Families. Do none of those fit your needs? If not, are you not able to modify one of them to fit your requirements?
Like I said before: Google it and they will come.  Kinda like Field of Dreams. Smiley Wink
Message 12 of 16
Where are they, can you send me the link? I could not find normal family.
Message 13 of 16
Mine are located in the OOTB Library ("Structural Connections" =>"Mounting Parts"=>"Anchor Bolts")
Message 14 of 16
eric.zhang305
At this time since there is a limitation of the program I would suggest to submit to Revit Idea.
Message 15 of 16
hazel.yangLP4MN
Observer
Observer
Is it possible to add new types into anchor bolts families now? 2023 version?
Message 16 of 16
robertwmerriman1
Hi @hazel.yangLP4MN and everyone else in this thread
If you are using anything from the steel tab the bolts and anchors are not Revit families. Everything in this Steel tab has been taken from Advance Steel (Steel detailing software which is part of the AEC collection)
For new Anchors they are based on the anchors from Advance Steel, to add new anchors or sizes this needs to be done via the Advance Steel databases please see the Autodesk Video below
https://www.youtube.com/watch?v=gGCvrv2vIVM
Once you have your new anchors you need to get them into Revit, all the Revit bolts and Anchors are taken from the Advance Steel databases which have been copied into the Revit folder Structure, so you need to copy the Advance Steel Database with the new anchors and paste it into the Revit folder structure. Please follow the steps below (Again please note i am working on UK builds so the fodler paths will be different)
1. Shut down Revit and Advance Steel
2. Go to the following folder - C:\ProgramData\Autodesk\Revit Steel Connections 2019\en-UK
3. Rename the AstorBase.mdf to AstorBaseOriginal.mdf (Always best to have a backup)
4. Delete the file AstorBase_Log.ldf
5. Go to the following folder C:\ProgramData\Autodesk\Advance Steel 2019\GBR\Steel\Data
6. Copy the file AstorBase.mdf and paste it into C:\ProgramData\Autodesk\Revit Steel Connections 2019\en-UK
7. When you reboot your Revit you will now have the Anchor that you created in Advance Steel available inside your Revit Base Plate connection
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
