Analytical model not showing up
natia_gurgenidze_3
natia_gurgenidze_3
Hello everyone,
While working in Revit2025 on a truss i cannot find the analytical model. I went through the analytical model categories and all the boxes are checked, although i can not find a category for structural elements.
I know i can use analytical automation, but would like to know if there is a way to fix this issue regardless.
Thank you in advance!
jay_colc
You need to turn on the Model Categories to show Physical Items as the Analytical Model Categories only shows Analytical Information (Nodes/Lines/Panels/etc.) so no Structural Columns as these are Physical entities
Revit no longer automatically produces an Analytical Model, and you have create these elements using the Analytical Automations Tools
Help | Analytical Model Migration Guide - What's Changed? | Autodesk
Help | Course: Create Analytical Models | Autodesk
Jay Colcombe
Autodesk Certified Instructor
natia_gurgenidze_3
Thank you, although i have tried Analytical Automations and i had to manually fix it, so in this case it was not very convenient.
jay_colc
I have also had problems with Top Chord lines and End Vertical wires not connecting properly in the Automatic process!
Jay Colcombe
