I'm new to the analytical automation process. When i open it up there isn't a physical to analytical option for me. Any ideas?
Solved by fjaegerQD7FG. Go to Solution.
Go to the following location:
C:\ProgramData\Autodesk\RVT 2024\Dynamo\samples\en-US\Revit\AnalyticalAutomation
You should have 2 .dyn files in there:
If the scripts are not present, you could try a repair of Revit, from Control Panel. The files should be copied to the location.
My box is not greyed out, but when I attempt to generate an analytical model and I hit the "play" button, I am not given the option to select anything. It says "running" and then "run complete".
