alignment of c-channel along arched ub beams
adper27
adper27
how can i do that?
see snapshot below.
Thank you in advance.
Corsten.Au
Corsten
Building Designer
adper27
this is how I did but isn't working. see attached snapshot
Alan.johnson1970
I have got round this before by editing the c-channel/pulin family,
and in Family Category and Parameters > un tick Always Vertical.
Load it back in to your project, This will enable you to create the array.
Then ungroup the C-channels and use Cross-Section Rotation to set angle relative to the curved beam for each instance.
AJ.
