Align analytical slab to modified sub-element slab
I have a slab drawn in at a specific level then used modify sub elements to adjust each corner to take the shape of my model.
My analytical model does not take the same shape. How do I adjust my analytical slab to the shape of my sloped slab?
I have attached the sloped slab and the analytical slab.
Thank you in advance.
I have attached a portion of the model. I hope this helps explain things better.
teodorb
Hi @Anonymous,
Firstly you need to define a reference plane parallel to you modified slab and name it.
The steps to perform to obtain the section where to draw the reference plane is described in this video:
https://www.youtube.com/watch?v=6ogcTOsnypY
After that you can select the analytical mode, and in the properties under the 'Analytical Alignment' you should select the Projection as Alignment Method, and for Z Projection you should use the reference plane previously defined.
Let me know if you need additional information. i have attached a R2019 model
Bogdan Teodorescu
Product Owner
teodorb
Here is the recording: https://autode.sk/2zuAZrJ
I have also attached the R2018 model.
Kind regards,
Bogdan Teodorescu
Product Owner
@Anonymous
Hi, im curious to know why would it be important to modify the analytical slab?
Hi @Anonymous,
The engineers needed flexibility to have variable loading with the analytical model, also to bring into Autodesk Robot.
Regards
