Adding label to spod elevation
cmiyares.mcsal
759Aufrufe
4Antworten
Nachricht 1 von 5
cmiyares.mcsal
Hi Everybody, Quick question ( and probably very dumb)...how can I add a label to spot elevation?
In this article said that you can but do not explain how.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Working on Revit Structure 2019, Window 10.
Thank you for any help
0 „Gefällt mir“-Angaben
760Aufrufe
4Antworten
Antworten (4)
Nachricht 2 von 5
MostafaElashmawy
The easy way:
Select the spot Elevation and add a suffix or prefix.
Mostafa Elashmawy
Nachricht 3 von 5
cmiyares.mcsal
Thank you very much Sr. for you reply.
Your suggestion it won't work for me..because I'm trying not to do it manually I want to add a formula to the label to show the value the NAVD Elevation for all the spot elevation I have in plans. See the picture below.
Nachricht 4 von 5
MostafaElashmawy
You can do it in the type properties.
Mostafa Elashmawy
Nachricht 5 von 5
You can copy paste aligned the spot elevation and change it to a different type that is based on Survey point.
