First floor Item Showing in Ground floor why? (View Range is OK)
My first floor Beam and Slab got selected from ground floor, even in 00 view range due to which i am unable to work with wall, please help me out...
MostafaElashmawy
Would you please show a section in your beam and floor and the top and bottom levels?
Mostafa Elashmawy
hmunsell
the Bottom offset for your view is -1200 and your View Depth is -1800. if that is going Down past the next floor you will be able to select the elements that are within that range. do they need to be that deep?
Howard Munsell
Here i Have 3000 offset between levels, if I set -1800 & -1200 to zero still it showing first floor beam and slab.
hmunsell
like @MostafaElashmawy  requested, can you please post a screen capture Section showing levels and the elements in question. Also have you checked your underlay settings?
Howard Munsell
andreylukach8C8M7
Tune the primary view range:
1. Top - 0.1.Ground Level - offset 0.0
2. Cut plane - 0.1.Ground Level - should have negative offset -1000.0 (example)
3. Bottom - 0.1.Ground Level - offset - the value of the depth of the floor.
4. View depth level - 0.1.Ground Level - offset value is the same as for the "3. Bottom"
In your presets - you have some view range above the ground floor showing what actually located on the 1st floor.
Otherwise check the presets for beams, on which level location lines are placed.
This should help.
