Adding filter rules, pressing space bar makes a double space
Duard.Erasmus
Duard.Erasmus
I've been trying to set up AND Filter rules with the "does not contain" parameter in Revit 2019 and couldn't get them to work. After 30 mins. of trying I noticed that when pressing space bar a double space is made which caused it not to match because of the double space. After removing the extra space it works fine, is anyone else experiencing this double space issue?
Corsten.Au
just a thought..
try onscreen keyboard and check if that also giving you two spaces..
Corsten
Building Designer
