Add host function
Add host function
JPNR87
Add host function
JPNR87
Hi!
in Revit 2022 we have new function "add host". It should allow to add leaderlines to tag and COUNT the elements added.
Is it possible to add this counting function to older tag familys? I have problem that my custom tag (created in 21 version) is not counting elements in tag
https://youtu.be/6mUSw9QAFts?t=466
Thanks!
ovidiu_paunescu
Hi @JPNR87
Yes, you can add that to any tag family that you load into Revit 2022.
To do that
  • Edit the tag family
  • Select and edit the tag label
  • Go to the dropdown menu above the list of available parameters (the default value in that menu will be the current tag category - e.g. Structural Framing)
  • Select Multi Leader Tag
  • Now add the parameter Host Count to your label and load into the project.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
JPNR87
Thank you!
Favioadl99
Observer
Observer
Thanks you a lot, have a good one!
