3D Rebar per view
3D Rebar per view
3D Rebar per view
It looks like I can only set rebar to display as a 3D object as an instance propert of the rebar? Can I set it per view or anything? Thanks.
dzanta
try starting with 1 view and setting the display the way you want.
then, save the view as a view template
then, apply the new view template to another view
it should work
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
That's the thing, there doesn't appear to be any way to control it per view. The only way seems to by an instance parameter on the rebar it's self. Once you enable it for that view (on the rebar properties), you can by setting the view to Medium or Coarse. But no matter what, you first need to enable it on the rebar. Unless i'm missing something. It might be a performance safeguard. 😕
Rafal.Gaweda
Autodesk Support
Autodesk Support
Bryan
You are right.
Rafal Gaweda
