2018 Structural Connections
advandes
Advisor Advisor
Message 1 of 25
advandes
I just installed Revit 2018 and was reading about the "What's New"?, and read that there are over 100 new connections. That's great, but how do you download them? I have searched in my account and can't find the add-in? Any help would be appreciated.
AAG
Advance Design
Replies (24)
Message 2 of 25
pietroz
I am looking for the same thing, maybe there is a library to download like it was on Revit 2017, till now, I didn't find anything helpful for this, just waiting
Message 3 of 25
Rivera-Artes
Like previous versions will be a addon, I guess will be available soon.
William Rivera,
BIM Manager
Silman
Message 4 of 25
advandes
The documentation made it sound as though it was available...kind of misleading
AAG
Advance Design
Message 5 of 25
Like me
Message 6 of 25
advandes
Lucton,  We are aware of how to load them within Revit, but did  you notice in your screen shot that there weren't any connections to load?
AAG
Advance Design
Message 7 of 25
Help me load conection steel in Revit 2018
Message 8 of 25
Taweepong.S
Hi ,
I think  It's look like previous version .
After you install the Revit program , Please waiting for Update Structural Connection for Revit in Autodesk Appication Manager .
Best Regard ,
Taweepong S.
Message 9 of 25
samuelsanf
Connections is an Add-in on Revit, for now it's still not delivered.
When avaliable, When available, you can download it from Autodesk Desktop App or Autodesk Manage portal.
Autodesk Help Says:
Note:
Unless structural connection add-ins are installed, only the symbolic generic connection is available.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-B2CBA19E-3CA8-422F-AB7F-E04EDAEC556E
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
Message 10 of 25
Mikael_QUIJADA
Come on AutoDesk...
When I buy a new car I prefer to have wheels delivered with 😕
Mikaël QUIJADA
Accompagnement personnalisé Revit Structure
Projeteur Structure indépendant
www.strall.fr
Message 11 of 25
clintonmaulder
Ok, so the connections are now available. I have some questions if Autodesk would oblige.
1. Is there a metric option for the bolts, or a to add your own bolt sizes. Currently inch seems the only option.
2. Is there away to copy or apply the same connection settings to another fixing. ie the settings seem entirely instance based with no 'by type' options available.
CM
Message 12 of 25
clintonmaulder
I found my own answer to number 1. which is you have access to different standards under bolt type, AS1252 and AS1111, would seem to be appropriate for Australia/New Zealand.
Message 13 of 25
catalin_lang
1. Also, you can check for DIN, EN, the ones found by you and many other bolt types.
2. There is no possibility to transfer connections parameters. The only way is to copy the entire connection.
catalin.lang
Message 14 of 25
advandes
So now we are getting messages that the connections are available and to use the Autodesk APP to download them, well when I launch the app all I get is a blank white screen, now I have to start a new complaint for that? I tried to find the connection add-in on my subscription site and still can't find them. This is crazy and frustrating. Can someone post the direct link to the 2018 Structural Connections add-in please?
AAG
Advance Design
Message 15 of 25
DarrenP
here you go:
Edited by Request
Discussion_Admin
DarrenP
Message 16 of 25
pietroz
Thank you a lot man!
Message 17 of 25
DarrenP
i am being told to not use that link anymore
there is an issue with it
DarrenP
Message 18 of 25
floreai
The Steel Connections Add-on can be downloaded from your Autodesk account: https://accounts.autodesk.com -> Management -> Revit -> Updates & Add-ons. Please see the attached picture.
Hope this helps,
Irina
Message 19 of 25
advandes
Seriously? How much longer does this wild goose chase have to last? The 2018 Steel Connections does not exist in my subscription search. See attached screen capture.
AAG
Advance Design
Message 20 of 25
floreai
Do you see any of the 2018 Revit Add-ons or is it only Steel Connections missing?
Thanks & Best regards
