Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
1st floor elements visible in 2nd floor plan
4 REPLIES 4
9521 Views, 4 Replies
Hello, I have a problem in my project, I can see 1st floor partition wall and some monolith slabs, with view range everything looks good, also partition wall is not going through slab, but I still see all these components from 1st floor. Looks like I made a mistake somewhere but I can't find what it is, maybe somebody know what might be wrong here?
4 REPLIES 4
ennujozlagam
Hello, in the properties set to none your underlay. If you look at your screen shots on left side top portion just change that. Thanks
in reply to: ennujozlagam
Thank you, I knew that is something simple as that, but could not find answer anywhere, thank you again.
thanks.
miamijac12
Running lt Suite 2021 Revit, underlay top level does not list none
