12D model import into Revit using IFC
BJX916_XUANWU115
BJX916_XUANWU115
Hi, not sure I am in the right place to post this issue.
I am trying to import a 12D model into Revit using IFC format, but after importing the 12D model into Revit, it becomes a whole entity and we cannot select individual element to get data information from the model.
The category of the entity is site. The 12D model includes just tins and strings. We assume that we should map the tins and strings with Revit family category, but we don't know which category to map with.
Does anyone have any ideas about this issue? Thanks a lot.
jay_colcombe
Linking IFC does act as a whole entity, you need to use the TAB Key to cycle select elements within the IFC model.
You could try opening the IFC and investigating it further as this allows more flexibility but as with ALL IfC models the level of information available is based on the Conversion Method when creating the IFC as to when level of information is presented and how.
Jay Colcombe
Autodesk Certified Instructor
handjonathan
Hi @BJX916_XUANWU115
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
BJX916_XUANWU115
Hi @handjonathan, thanks for checking, but the issue hasn't been solved yet.
jay_colcombe
I would suggest after looking into the further that the limitation lies with the lFC export from the legacy software.
I did find a link to their site with a process which maybe if help on creating IFC files.
https://12dwiki.com.au/12d-data-to-revit-model-via-ifc-export-option/
 Here is a reference to the file type required;
https://12dwiki.com.au/bim-and-ifc-reference/
Jay Colcombe
BJX916_XUANWU115
Hi Jay,
We think that it may be the issue in the exporting side, we are still working on it.
Thanks.
jay_colcombe
No problem, looking at the information it appears Tin can only be exported using IFC4x1 so it could be the limitation here.
Keep the thread updated for other users.
Jay Colcombe
