社区
Revit,Navisworks建筑施工BIM讨论区
欢迎访问欧特克Revit, Navisworks论坛!分享知识,发帖提问,浏览论坛热帖。
取消
显示结果
显示  仅  | 搜索替代
您的意思是:
软件显示显卡未测试
3 条回复3
已解决
回复
1 条消息(共 4 条)
1048 次查看, 3 条回复
软件显示显卡未测试
使用软件为revit2020版,显卡为amd wx3100,在官网安装当前版本支持的驱动后,打开软件还是显示视频卡未测试(cpu为amd3600,没有核显)请问是为什么
3 条回复3
2 条消息(共 4 条)
mdavis22569
回复: Anonymous
Hi @Anonymous
For:
The software shows that the graphics card is not tested
The software used is the revit2020 version and the graphics card is amd wx3100. After installing the driver supported by the current version on the official website, the software still shows that the video card is not tested (cpu is amd3600, without verification). Why?
The Cards have to be submitted by the company. AMD in this case.  Autodesk doesn't pick and choose out the 1000's of cards what ones to certified.  Nvidia / AMD provide the card and they are tested in various ways including drivers.
So if it's not on the list, then likely it didn't get submitted or it failed.
That's why they make the certified list to referece.
Mike Davis
3 条消息(共 4 条)
回复: mdavis22569
1.png你好,先生,我在autodesk的官网,我找到:2020revit,显卡为Wx3100 4GB,显卡驱动为19.Q2,从这个下载链接去下载,安装后我也查看了我的显卡驱动,版本号没有错,这些信息都是从你们autodesk的网站上找到的,那么我的显卡和显卡驱动都没有错误,但是软件中却显示未测试,请问这是什么原因?
4 条消息(共 4 条)
mingway
回复: Anonymous
我没有这张显卡,但我在AMD官网找到另一个产品支援网站中发现:
REVIT 2020目前测试过支援WX 3100 的驱动程序版本应该是 19.Q4
可以再试看看19.Q4这一版本是否符合需求
https://www.amd.com/en/support/certified-drivers?f%5B0%5D=application%3ARevit&f%5B1%5D=application_v...
以下为个人想法,仅供参考
实务上,显示未测试只表示这一版驱动没有经过测试
例如:新版驱动只是還未安排測試,并不表示它不能有效地支持软件运作
Mingway
Product Support Manager
Concord Tech Co, Ltd. 協勤資訊有限公司
LinkedIn
找不到想要的内容?向社区提问或分享您的知识。
到论坛发帖
