Work arounds
Work arounds
Work arounds
So I am getting close to the right HVAC calculations for a project I am doing but still have a few questions.
1) Why does on the first floor of a 2 story building does it still calculate a roof load and usually this value is higher than the actual roof level?
2) Has anyone got any closer on getting this system to work, is the only reason it doesn't work because of the R-values not calculating in like I have read in other posts?
3) Why does the whole building peak load not match the top level and bottom level added together?
4) What is different from the space load to the zone load? Even if there is only one space in the zone?
thanks.
christian.riley
Autodesk Support
Autodesk Support
@Anonymous -
I am currently working on getting you as many answers to your questions as I can. Thank you for your patience.
Christian Riley
Technical Support Specialist
christian.riley
Autodesk Support
Autodesk Support
@Anonymous -
I was able to touch base with the development team and do have a response for you.
The built in load calculation programming is actually a bit of an old feature that has not had a lot of manpower behind it. The team is currently working within the Insight program, and going forward that will be the staple for the load analysis within the Revit workspace as it handles imperfect modelling a lot better.
I do have a couple of links for you with webinars for Insight as well as a How-To video. While Insight's primary focus is energy analysis there is a packaged Load Calc portion that the How-To goes over.
Learn everything about Autodesk Insight – Episode 1: Overview
Learn everything about Autodesk Insight – Episode 2: Tips & Tricks
Insight How-to Video Collection
All of these links do require you to login, though they are completely free. The logging in function serves more as a guest book.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Christian Riley
christian.riley
Autodesk Support
Autodesk Support
@Anonymous -
I just wanted to check in and see if this information was able to help.
Christian Riley
I have not had a chance to work with the insight program. I will get to that in a few days maybe.
Thanks for your insight!
