Hi @Anonymous,
Hope you are well.
Below is a list of possible things which you can check/double check which will override Wire Colors:
Was the Object Styles possibly changed?
Manage Tab >> Settings >> Object Styles (Next to Materials) >> Model Objects >> Wires (Right at the bottom). Clear/Change overrides. (Different from VV overrides).
Then, check to see if your Wires Category wasn't accidentally checked with another filter which has been applied to the view. e.g. - You have a Red Color filter for all your "Lighting Fixtures Category" and the "Wires Category" was accidentally checked when setting up your Lighting Fixture Filter.
Other than that, you already mentioned that you check your VV and no overrides were assigned to Wires, then just check the above-mentioned and let me know if it resolved your issue.
I hope this helps!
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
