- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I am having problems when circuiting a set of luminaires which although some are emergency are all fed from the same circuit. My luminaire family has only 1 x 230v connector and one data connector for connection to TCP/IP monitoring of emergency . I have circuited the fittings so they are all from the same DB and circuit. However when I try to tag them the tag shows 3 circuits as if it was a 3 phase luminaire?
When I investigate the fittings are on the same circuit, and only have a single phase power connection. For some reason the wire serving the circuit keeps changing from 6242B B (2) 2 conductors (1 Hot, 1 Neutral plus CPC) to some strange 6242B B (2) with 2 Hot conductors, 56 Neutral conductors and 2 Ground?
How can it be possible to specify a 6242B B (2) cable where the material specified states "copper table 4D2A Ref Method B two core cable with or without CPC" with 2 Hot conductors, 56 Neutral and 2 Ground? Such a cable does not exist so why is it possible?
