Which family template to use for creating a VCD (Volume Control Damper)?
BalajiHTI
BalajiHTI
Hello All,
I need to create a VCD which comes in between a Duct face and a Supply/Return Air Grill. Which template is suitable for this and after creating the family, which category should I choose? Like Air Terminal or Mechanical Equipment?
VCD Family Template
Thanks in advance!
L.Maas
If it is part of the duct system the most common category would be a duct accessory.
Please note that Revit has several dampers available in its libraries under Duct\Accessories\Dampers.
Louis
Please mention Revit version, especially when uploading Revit files.
BalajiHTI
Thanks a lot EnlInt!
Also I tried to place the three (Air Terminal, Damper, Duct )in a project. But the result is not desirable.
Is such a connection possible as shown below? Can you please help me which elements I have to choose for them? I have complete UK and US Libraries.
VCD Placement
L.Maas
It depends on what your definiton is of desirable. The fitting is a typical shoe branch which can be found in the libraries under fittings.
The grilles can be found in the libraries under Mechanical\MEP\Air-Side Components\Air Terminals
Then it is possible to create something like this
It is always good to check with manufacturers if the solution you have thought of is a possbile solution.
Also seek.autodesk.com is a good source for finding solutions
Louis
