When I rotate the tee family, revit changes for another family
uoliveira
uoliveira
Hi Guys,
I have modelled this tee family (90 degrees), which has some problems when I try to rotate it. I do not know but maybe is regarding the function of the routing preferences. Then, when I rotate using the default command into Revit, it changes for another tee family loaded before which is with 45 degrees. How can I rotate and make it does not change for another family and remains the same?
Thank you!
ennujozlagam
go to family and untick always vertical and see if helps?
fabiosato
First point, all connectors must be fittings.
The center connector needs the angle parameter attached to its angle parameter.
I advise making one family that flexes to the desired angles; this is how Revit expects the family to work.
Attached the revised family for testing.
Fábio Sato
