When changing the air flow of the air terminal in the properties, an error message of "Enter a value or formula starting with "="" appears in Revit.
sburtonJAMXV
sburtonJAMXV
As mentioned above, when changing the air flow of the air terminal in the properties, an error message of "Enter a value or formula starting with "="" appears. Does not matter which family is used. Asked around and another person in the office has experienced the same problem starting this week.
Found a get-around, which is to tag the air terminal, then through the tag (Delayed double-click) modify the air flow. Anyone know of a proper solution?
iainsavage
handjonathan
Hi @sburtonJAMXV
Thanks a lot for posting your question to the forums!   Has the solution suggested by @iainsavage helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
sburtonJAMXV
It appears that updating Revit to the newest version (Revit 2024.3.1 Update) does resolve the issue. For those who can't update right away use the workaround I mentioned in the first message or use the "Modify | Air Terminals Flow: 0 CFM" bar at the top of the screen. (Though your Flow Parameter needs to be set = ###_Flow Parameter).
Thanks for the help @iainsavage.
jdeyoung
this is happening to every family I have,  Somehow Mechanical-Flow has been added to every mechanical equipment and duct accessory family I have ever created and makes the family un-editable.
iainsavage
That sounds as though someone has added a Project Parameter in your project or template and then associated it with those categories.
Or maybe they've used a utility like DiRoots Paramanager to add a parameter en masse to every family in certain categories.
I don't think Autodesk parameter names would be hyphenated so I think this is a custom parameter.
