Line cover Revit to CAD
pe_simon
pe_simon
Hi, When I exported the revit to cad , in the autocad (the picture shown below) the down pipe appear and cover the sprinkler head symbol, I need to del it the down pipe symbol and little line....how can I disable the down pipe in revit or before export or can fix it? Thanks.
iainsavage
Turn off visibility of rise and drop symbols in the view that you are exporting from?
pe_simon
But some pipe rise and drop not connect the sprinkler head, shall not be shown off...
iainsavage
So is the symbol in the sprinkler family?
pe_simon
yes. But the symbol or detail line can not cover the rise and drop pipe after convert to 2D cad file.
iainsavage
So if I understand correctly, piecing this together from your various statements, you do want the rise/drop symbol to export to CAD for most pipes but you don't want it to export when it is a drop onto a sprinkler?
I don't think there is a way to be as selective as that unless you're going to start applying a parameter value to every pipe (and elbow?) which drops onto sprinklers so that you can apply a view filter to switch off visibility of those elements.
