Walls not visible
Walls not visible
tmccar
Advisor Advisor
Message 1 of 21
Walls not visible
tmccar
I have inserted a background which shows some concrete tanks. I can see a plan view of the tanks when in a "ground level" plan view, but when I switch to the top tank level, the walls are not visible.
    I have tried this in the background file, and the walls are visible (although they are slightly faded).
Replies (20)
Message 21 of 21
iainsavage
@rocioavictoria 's solution was based on using the Underlay settings but this method isn't straightforward in MEP models when the architecture is in a linked file. The underlay settings also refer to the Level below, not to a particular view so its difficult to control view settings for the underlay.
The marked solution is however to extend the bottom plane and view depth to a low enough value to cut through the walls below. You might also need to adjust the cut plane if you want to cut through the walls/doors/windows etc rather than looking down on top of them.
Post a screenshot of a section view and also your view range settings in the corresponding plan view.
