i've created some views and sheets with scope boxes but the scope boxes can only be set as rectangle i assume?
In my case i want to make a part of the view invisible on the sheet because that's a different appartment which is viewed on
another sheet.
Please see the attached pic.
Thanks!
Jan Kreiter
Solved by ToanDN. Go to Solution.
Don't use scope box so that you can edit the view crop boundary. Or create a legend view with a masking region and place it over the area you want to omit.
