Visibility Based On Reference Level
fgleason36CXH
fgleason36CXH
Is there a way to manipulate the visibility settings to have families appear on a floor plan based on the reference level regardless of any offset?  Such as if I draw some ductwork on Level 2 of a building and I have the reference Level of said ductwork set to Level 2 and that ductwork only shows up on the Level 2 floor plan regardless if I put it at 5'-0" above the floor or below the floor, which would technically be Level 1.
I'm working on a building that doesn't have one flat roof along with random rooms with high ceilings, for example the floor to floor measurement could be 10'-0" but somewhere in the building a room has a 12'-0" ceiling and I have to put ductwork above that ceiling, the room itself is on Level 2 of the building but the ductwork will register to be on Level 3 since the ceiling is so high.  I know I can adjust the offset of the view range but that just makes the floor plan a mess with having other things show up and I'm just wondering if there is some secret way to make families and other components visible on a floor plan based on their reference level.
iainsavage
See this link: https://forums.autodesk.com/t5/revit-mep-forum/filter-or-select-elements-by-level-or-working-plane/t...
You could also explore the use of Plan Regions to locally alter the view range in specific parts of an overall plan.
RSomppi
Plan regions and part plans.
fgleason36CXH
Thank you so much! I did not know that this was even a feature in Revit.  It will definitely help me clean up my plans
