Viewport boundary is too large
Message 1 of 8
Hello everyone, I have a long plan view but I want to print out only one small portion of it. So I created a sheet and attached on it the cropped viewport of the initial view. The problem is that I am getting extended viewport limits out of the cropped area that are finally printed in the exported AutoCAD file. Check the attached image. PS. This is a mechanical model and it is linked with an architectural model. The architectural link is probably the one which creates the problem through its grids and axes. But I don't have access on it. Any Ideas how to solve the problem?
Replies (7)
Message 2 of 8
J.Wehmer
Make sure that annotation crop and crop region visible is not checked;
-Please click accept as solution if this answers your question!
Message 3 of 8
ennujozlagam
hello, you need to go your view and adjust the crop view see attached. thanks
Message 4 of 8
Thank you both for your reply. It is the ARCHITECTURAL Link that causes the problem. When I activate the Annotation Crop button nothing changes. It is only solved when I deactivate the grids of the ARCHITECTURAL Link. So, there is no way to control the viewport range?
Message 5 of 8
Message 6 of 8
J.Wehmer
If you turn on the crop region visible, a box appears where you can drag the crop region
Message 7 of 8
bim9QCA4G
In visibility settings uncheck the site under model category. It will reflect when you will check the Architecture in filter option.  It works for me.
Message 8 of 8
ECODG90
Community Visitor
Community Visitor
Yes, this worked for me. I had the same problem, I had a lot of Revit links and I had to uncheck the site on each link.
