V with a dot over doesn't appear correctly
Hi guys,
I'm having a problem with the letter V̇ in Revit.
When I type it in text editor, it appears correctly up to a point where I close the text editor. At that point the dot goes down and a bit to the right, and stays there whatever I do.
I type the letter with V+0307 and alt+x after that.
The problem might be that when I go to Symbols/Other in text editor, I can't find that particular letter. There are a lot of other options, but not this one.
Any ideas ?
Does this have anything to do with Revit, or it's rather a Windows problem ?
How should I resolve this because it is becoming annoying, and it used to work before ?
Thank you.
mpeperkamp
Hi @Anonymous ,
I can get it done, which version of Revit do you work for?
What type of font do you use within Revit?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
I use Revit 2018 and 2019. Both of them are giving me the same problem.
I'm using Arial as a font.
Still no solution.
Anyone has any idea ?
