Using Trim/Extend with Fabrication parts placing rolling offsets instead of 90 offsets
devin.prosser
devin.prosser
In Revit 2020 when using trim/extend to create 90 offsets it is making a rolling offset instead. However, when I use route to fill I am able to make the 90 offset, but our team is trying save time by using the Trim/Extend tool. Does anyone have any suggestions or solutions to this issue?
Using Route to Fill
Using Trim/Extend
robert.klempau
Hello @devin.prosser,
Go to your MEP Fabrication Parts pallet and select the 'Auto Fill Exclusions Mode' (1)
Then select the 45-degree angle fittings you want to exclude.
Then try Trim / Extend again.
You will get the result below.
By default, the fittings are not excluded for the routing solutions and Trim/Extend functions.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
devin.prosser
Do you have an idea of the priority of fittings it chooses? For some reason it is trying to put a tee instead of an elbow. I can exclude the tee and it works, but I was just curious if you knew why
djthompson
It simply runs through the fittings in order starting with the first entry Group dropdown and then through the buttons in that group.
You can get good results if you put things in a logical order.
For instance-
Group 1 Smaller threaded pipework
Group 2 Larger welded pipework.
In the groups-
90 deg bends before 45
Reducing tees before Equal.
