Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
.txt file location
8 REPLIES 8
Message 1 of 9
1173 Views, 8 Replies
.txt file location
hi all,
I have created a revit family file and .txt file with different configurations in it. (Both names of family file and .txt file are same).and are stored in same folder. when I load the family file into project it works fine with table loading in it. but when I store the .txt file at different location and open family file in project it does not open the configuration . please let me know how this issue can be solved.
*** My requirement is to store all *txt file in particular location and family files at different location but when files are loaded into project it should work fine with configuration loading in it.***
I use revit 2016 version software
8 REPLIES 8
Message 2 of 9
RobDraw
As your tests have confirmed, the file needs to be in the same location.
Rob
Message 3 of 9
Yes, but I need the .TXT file at different location that the revit family file
Message 4 of 9
Is it possible to store .TXT file at different location
Message 5 of 9
jeroen_vanmassenhove
No
Message 6 of 9
RobDraw
Sure, keep it anywhere you want but you will need a copy of it in the same location as the family. Until things change, you need to keep it in the same location with the same name as the family.
There isn't another option, yet.
Rob
Message 7 of 9
Well ,the real problem is the revit family file size is 850kb and .TXT file size is 4.5 mb which contains 7500 configurations in it . We have to publish it into our website.
Message 8 of 9
We'll, the real problem is that the revit family file size is 850 kB and . TXT file size is 4.5 mb with 7500 configurations in it. we need to publish these files into our website.
How can I integrate both revit family file and .TXT file so that I can reduce the file size less than 1.5 mb. (With all 7500 configurations data).
Please help!!!
Message 9 of 9
We'll the real problem is that the size of revit family size is 850 kB and . TXT file size is 4.5 mb with 7500 configurations in it. We need to publish these files into our website.
How can we integrate both the revit family file and.txt file so that file size is less than 1.5 mb combined
