Two references for homerun/ electrical circuits
rawan_dababneh
rawan_dababneh
Community Visitor
Community Visitor
I am working in a project where some of the lighting fixtures are connected to two power supplies (normal and central battery) and hence some identified with E at the symbol are with two connectors.
When I do the circuiting, I am having a problem as some of the normal lighting homerun shows the correct panel however with two circuit references for the normal and emergency. How can I solve this problem without having the need to delete all the wires as I am almost done and this will need a huge rework.
debimmanager
Trying to understand your situation and I really don't know how you have structured your systems, I think that you should first separate the circuits, you have the normal one in the same emergency circuit and that should be separated. Emergency is emergency and normal is normal. After you separate them you can label and work independently each circuit and system and it will be much easier.
Kudo if you consider it and mark as a solution if it helps you solve your issue.
Thank you!!
Deivis E.
REVIT® MEP Specialist
