Revit MEP Forum
Turning off ADA clearances in Revit links
10 REPLIES 10
Message 1 of 11
cspence
2506 Views, 10 Replies
cspence
Hi All,
I'm very new here to the Revit world. I'm working on a project where I have linked in the Architectural Revit model, but I would like to turn off all ADA clearance zones around doors, toilets, etc. I can't seem to find a way to do this through the Visibility Graphics. I can turn them off on a few select doors by unchecking "Elevation Swing" under "Doors" in VG's, but the ADA clearances still remain on around other doors, and within all the bathrooms. Any help would be greatly appreciated. Thanks!
Hi All,
10 REPLIES 10
Message 2 of 11
RobDraw
in reply to: cspence
RobDraw
Unfortunately, when dealing with ADA clearances, it's multiple moving targets depending on who created them. They are sometimes a line style that can be turned off globally. More likely they are subcategories under the family type. There are worse scenarios also. Your mileage may vary.
Rob
Rob
Message 3 of 11
HVAC-Novice
HVAC-Novice
you need to find out what those clearances are (likely a sub-category). i use subcategories for installation clearances and created a sub category I only show in the views i want (i.e. a boiler clearance would only be visible on mechanical views, not structural etc.)
If the person who created them didn't use a separate sub-category... tell them to do it right.
Revit version: R2025.3
Message 4 of 11
hmunsell
hmunsell
as @RobDraw & @HVAC-Novice  said, it can be a couple different things. can you upload a couple of the families for us to look at?  Then we can better point you in the correct direction.
Howard Munsell
Howard Munsell
Message 5 of 11
tbowmanUN6NM
tbowmanUN6NM
Community Visitor
Community Visitor
Dang!
Dang!
Message 6 of 11
RobDraw
in reply to: tbowmanUN6NM
RobDraw
Even though you totally changed your response, I'm going leave this out there.
Revit didn't make it complicated. It's easy once you know what is going on. The problem is there are many ways of creating them and users do what they think is right or works for them. You need to be prepared for the way your sources do it and know how to figure it out. If it were actually complicated, it would probably be more predictable.
Remember, not everyone works in your little box.
Rob
Rob
Message 7 of 11
kadmonkee
kadmonkee
open a detached copy of the Architectural model and investigate your issues in a live model.
you can see how families are created and backwards engineer them to understand how they work then control those issues in your model through manage links settings
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
thank you
Message 8 of 11
SeanThorndike_SDG
SeanThorndike_SDG
I the same issue all I want is to turn off ADA in my structural model.
Message 9 of 11
SeanThorndike_SDG
in reply to: RobDraw
SeanThorndike_SDG
Can you help?
Can you help?
Message 10 of 11
RobDraw
in reply to: SeanThorndike_SDG
RobDraw
All the information you need is in this thread already.
Rob
Rob
Message 11 of 11
SeanThorndike_SDG
SeanThorndike_SDG
Yes sorry I should have read all the post.
