Transfer Flex Duct - Flex Pattern from Project to Project
ali_jackson88NHL
ali_jackson88NHL
Is there a way you can transfer the Flex Pattern from Project to Project, I guess what I'm asking for also is where is the graphic for the Flex Pattern in the Project Browser.
apjones
Set the pattern the way you want it in your project template.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
djthompson
I think if you place an instnce of the flex in project 1 you should just be able to copy/paste it between 2 open projects in 1 session of Revit.
