Text parameter issue in schedule
alpawar.ind
alpawar.ind
Hi Everyone,
I have some issue with text parameter on schedule as attached screen recorder.
Thank you
apjones
Change your parameter from a type parameter to an instance parameter.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
hmunsell
as @apjones mentioned those are probably Type parameters and editing them will affect any parameter in a family of the same Type.
if you need different sized panels, make a new family type with the correct dimensions and use the new type in your project.
Howard Munsell
