Text - How to set indentation in a paragraph?
Message 1 of 11
I have a paragraph of text (using the automatic numbering per new line) and I cannot figure out how to automatically indent non-numbered lines to a certain point; I have to hit tab at the beginning of each line, and this can be annoying if I have to make revisions to said text.  Is there a way to automatically indent, or must I do this manually?
I am running Revit MEP 2012, and thanks in advance!
Replies (10)
Message 2 of 11
Since Revit has no word proccesser you must do this manually unfortunately.
Message 3 of 11
abulla
Just don't resize your text box, it will screw up all that indenting. Neat huh?
Message 4 of 11
Have you tried the "Text Generator" tool in the Autodesk Extensions add-in from the subscription site? That allows you to import externally created text and provides a little more word processing power thatn the usual text editor. That may help.
Message 5 of 11
I have downloaded and installed the REVIT 2013 extensions, but I haven't a clue as to how to use them.  Can someone please direct me to a help link?
Message 6 of 11
Seychellian
Any updates on this one 8yrs down the line?
Message 7 of 11
j_em_doubleu76
Not that I've found - crazy (and now 10 years down the line)
Message 8 of 11
Message 9 of 11
j_em_doubleu76
In my example I need to hit TAB at the start of each line - not ideal in large bits of text, and not intuitive if text is edited.
Message 10 of 11
I see.  If you want unconventional numbering then use a noteblock schedule.
Message 11 of 11
j_em_doubleu76
Ok thanks, one day in the future I may have time to look into that properly. A quick look was not enough to understand how to use them - same with adding a quick text table.
