Terminal Scheduling by Level
Message 1 of 33
Can someone please explain to me the logic as to why some schedules can be filtered by level and others not. Why is it I can do it with a Mechanical equipment schedule but not with the Terminal schedule?
Yes you can create a work around by using multiple category schedules and then just filter family type but then you lose some of the paramters specific to that familiy. I mean if I have a 20 story building and I need to create terminal schedules by floor whats the correct way to go about it?
Ryan
Revit MEP 2013
South Africa
Replies (32)
Message 21 of 33
What is linked, the Air Terminals or the building?
Message 22 of 33
The linked is AutoCad .dwg drawing. 2D only.
And I am placing the ducts and airterminals over it.
-Regards
Message 23 of 33
-Regards
Then draw space separation lines to form spaces.  Make sure the air terminals are inside the space volume.
Message 24 of 33
Now it works perfect, after space seperation lines drew.
Thank you for your patient, time, and answer.
-Regards,
Sohaib
Message 25 of 33
ja1357
Quote 'We understand that this may not be the preferred workflow, but the request to have the "Level" parameter added to the list of scheduled parameters for Air Terminals has already been logged with our Development group'  This was in 2012 and I am now using 2019 and the problem still exists.
Message 26 of 33
RobDraw
Just because it was logged doesn't mean it will ever get to development. I'm surprised you haven't found a solution, like the ones in this thread, in the past 7+ years.
Rob
Message 27 of 33
ja1357
That is exactly what is wrong with Revit having to work around all the time. You say you are surprised I haven't found a solution I am not surprised as there are no solutions only workarounds for this problem, and yes I have resulted to using a bodge workaround but I could have save a bit of time if Autodesk would have listened to customers and fixed the issue
Message 28 of 33
RobDraw
I'm having trouble understanding how you can expect the program to do something that you admit is not a preferred workflow.
Rob
Message 29 of 33
ja1357
Don't get what you mean Rob? All I am asking for is MEP designers to be able to extract level data for families to make scheduling simple rather than having to tell the family what level it belongs to with tedious workarounds.  Many people would like this feature so it is not just me who sees logic in extracting level data from any family.  So what is your point?
Message 30 of 33
Level information is provided via Space, add that to your terminal schedule.
Message 31 of 33
ja1357
Hi ToaeDN
Thanks for your idea this does work with air terminals but the space level is not an available field for duct accessories and some other mechanical families.
I am not an expert so I am either using Revit 2019 incorrectly or the need for a level field is still required.
To get the level info associated with the attenuators I have created a shared parameter for duct accessories and added the level info manually to all Attenuators but I know this is not how I should be working in a BIM project as this information relies on manual input and is open for errors.
Please could you comment and advise on a good solution to my problem.
Many Thanks
James
Message 32 of 33
bvm76
In order to make sure you have the correct level in your level shared parameter, create a multi-category schedule and filter/sort it with level & duct accessories. Make sure the "Itemize every instance" under sorting/grouping is untick. This way you don't have to enter the level of every components.
Please mark Accept as Solution if your question is answered!
Thank You.
Message 33 of 33
You can show Level information for Air Terminal, Duct Accessories, Duct Fittings, and some others (I did not test every category) from a Multi-category schedule.
