Tagging the Elevation of a Hosted Fixture
coleLHPZ3
Message 1 of 28
coleLHPZ3
Hello everyone I am trying to see if there is a way to tag the elevation of a hosted element, besides just using text. I Know that this has been a problem since 2012 but I was wondering if anyone has come up with a solution in the last 3 or so years? Thanks
Replies (27)
Message 2 of 28
dzanta
do you mean like the image attached?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 28
coleLHPZ3
No what I am trying to accomplish is being able to tag a hosted fixture that does not have a parameter for its mounting height, because it is a hosted element,in a view not an elevation view. Right now I have to use text and if that fixture moves for any reason then the text height that I put in is now wrong, so I would like to try to find something that can work with the device so when it moves and the elevation changes so does the tag.
Message 4 of 28
dzanta
so here is a revit file that has a light fixture (wall mounted) on a wall.  It has an elevation parameter for the height.  I linked this into a new revit file (structural) and used the Spot Elevation command to get the elevation at various points.  See images 1 and 2.
After moving the light fixture in the linked revit file, I opened the structural model and the elevation tags updated properly...see image 3
Message 5 of 28
dtiemeyer
I think he wants the elevation tag to display in 'plan' view. We do the same thing for 'counter height and above' receptacles. A bit of text that says 48"AFF or 72"AFF, something like that where the 48 or 72 is the 'Elevation' value after the object has been inserted. I'd love an answer to this as well.
My other CAD is a Cadillac and I like to Revit to the Max!
Message 6 of 28
coleLHPZ3
Yes that si exactly what I am looking for. Using the 48" or 72" AFF is okay but it is a lot more time consuming.
Message 7 of 28
dzanta
like this?
Message 8 of 28
dtiemeyer
yes. Is that using a 'Fixture' tag or an elevation tag?
how did you 'snap' to that (in other words, what value did it read? Top, center, bottom, insertion point?)
Cheers,
Dustin
Message 9 of 28
dzanta
the solution is to create a shared parameter for the elevation parameter of the light fixture.  Once done, create a custom light fixture tag with a label that uses the custom shared parameter you just made.  After making the custom annotation, load it into your project and tag away.
Message 10 of 28
dzanta
i used the light fixture tag.
Message 11 of 28
dzanta
see shared parameter file I made...
Message 12 of 28
coleLHPZ3
Is this fixture a hosted element?
Message 13 of 28
dtiemeyer
But that will only allow you to manually fill in what you want the tag to read, it's not linked to the actual Elevation value, is it?
Message 14 of 28
dzanta
this custom annotation is reporting the elevation parameter...I am not manually typing in the height.
the light fixture is a face based/hosted light fixture.
this method works regardless if the family is a hosted or non-hosted family.
Message 15 of 28
coleLHPZ3
What about for a ceiling mounted fixture. Will this method work if I had a receptacle that is hosted to a ceiling and we want to show how the height of that device and if it changes without typing in a text box with the height.
Message 16 of 28
dzanta
it should
Message 17 of 28
dtiemeyer
would you please either post the Revit file, or a screen capture of how you have linked this shared parameter to the 'Elevation' field of a light fixture? Ive used your family, and it doesnt work on my end. Thank you.
Message 18 of 28
dzanta
1.  open the light fixture family
2.  open the family types window
3.  find the elevation parameter, choose edit
4.  change it from a family parameter to a shared parameter
5.  choose the shared parameter text file I sent to you earlier
6.  the shared parameter file will list all the shared parameters I made...one will say elevation..select it
7.  click OK to finish the modification of the light fixture family
8.  load the newly modified family into your project and tag away
Message 19 of 28
coleLHPZ3
I believe it should as well. My only concern is that I will not be able to add in shared parameter to pick up the elevation or mounting height of a hosted ceiling fixture because of the way that you have to build the family?
Message 20 of 28
dtiemeyer
'Default Elevation' is not allowed to be edited into a 'Shared Parameter' because it is a Built-in Parameter
