Hello Revit users, thank you for stopping by.
I know this topic is not the most favorite here, but I need to tag ducts from the upper part of the rectangular duct to the lower part of the ceiling, and the same for the pipes "but from it axis"
I tried to work around this issue and created levels based to lower part of each floor, however everybody will draw in those levels.
Thank you for the Help, have a good day.
you can use the( spot elevation) tool and when you select the tool from "annotion tap " then "Dimension" the "spot elevation" .
after selection the tool you can the reference level you want to tag from from " relative base "
in your case select the above level or create any level you want and you will find it in " relative base " then tag
you are right , but i think the spot elevation tool will achieve that you want .
