tag problem
tag problem
tag problem
I have a problem with plumbing tags.
I need to create a tag with basic parameters - pipe size, lenght , slope and open text parameter.
When i create my tag, text parameter missing in project.
Any suggestions ?
www.TechRoom.bg
I prefer your text parameter is shared , because theres havent basic free stand text parameter.
When you load your tag in project do this steps.
Go to Manage->Settings->Project Parameters->Add->click share->Select->pick your parameter->Choose category.
If you need more help about tags i'm ready to help you.
Good luck
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
Yes its share parameter.
And yes this solution work.
Thank you for fast solution.
I hava a qustion about pipe elevation tag.
www.TechRoom.bg
Theres havent pipe elevation tag as basic solution.
You must use elevation tag general for pipe bottom level.
If you need to help you with creating a custom pipe elevation tag which will work like a tag for pipe bottom level contact me on email.
Eng. Iliev L.
