system family name change
jagadeesh116
Message 1 of 13
jagadeesh116
hi,all
it is possible to change system family name??????????
Replies (12)
Message 2 of 13
RobDraw
Do you mean like changing "Walls" to "Vases"?
Have you tried it?
Rob
Message 3 of 13
s.borello
I don't believe you can change the name of a system family, however you can duplicate and re-name the family type.
Message 4 of 13
Hello @ jagadeesh116,
You can create new types of a system family and rename it but you can't change the system family name nor delete it.
Message 5 of 13
nick_benjaminNKJF7
Can you please tell me "how" you create a new system family?
My issue is attached.
Message 6 of 13
RobDraw
Your image is not showing system families. Your issue has to do with Disciplines and Browser Organization.
Rob
Message 7 of 13
nick_benjaminNKJF7
Thanks, Rob.
I can sort in Browser Organization, but it's that "structural" I would like to rename to mechanical. Can this be done?
Message 8 of 13
apjones
I strongly suspect that the plan views were created as Structural plans.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 9 of 13
RobDraw
Like I said, that's the Discipline (of the view).
Rob
Message 10 of 13
RobDraw
Just as likely, the Discipline could have been changed after the view was created.
Rob
Message 11 of 13
nick_benjaminNKJF7
Can the system family for the view ONLY be set when the view is created then? Or can I change it?
The drop done from attached has no other option than the structural plan. Laymans terms if you can please.
Message 12 of 13
RobDraw
The discipline can be changed in the properties of the view. If it's grayed out then it is being controlled by a view template.
Rob
Message 13 of 13
nick_benjaminNKJF7
Thank you, Rob
