For duct, pipe, etc. that are system based and related more to a level than a specific area, the answer is no, you can't automatically include this. When you're adding parameters, most schedules allow you to select from the main object category (like mechanical equipment) when scheduling components and then addition sources, such as the space or project information. For example, a duct schedule allows you to select project information but not space. Other items, like mechanical equipment, air terminals, lights, etc. do include this option. We've cheated this in the past by adding a project shared parameter called Location, and adding it to all objects in the duct/pipe categories. But this is mainly due to the fact that the pipe and duct are not space specific, and actually span multiple instances in most cases.
It would be a great idea to add these objects to the Revit ideas forum, but it would be a tough add. Are you just trying to do a materials list? Is the piping part of a set of pumps and other fixtures?
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
